Suggestions on what to do with NOS cab paint peel
bachman502
58
Chesapeake, VA
I'm looking for some suggestions hopefully by some experienced carc paint and primer painters. I picked up this NOS cab and it has a few spots of peeling paint. Upon my research, this is the water based carc with the white chromate and lead free primer. From what I have read, it's not the best at keeping the rust at bay. So my question is, what should I do with this paint/primer system? Should I blast it to clean metal? If so what should i prime with? And is water based carc the only option from Sherman Williams? If blasting is not recommended, how to I correct this issue and get a good feeling that more spots won't peel? Also I would like to add that underneath the cab is a nice undercoating that seems to be sticking pretty well. Also I do want to get the inside and possibly underneath Sprayed with Linex. IMG_4192.jpgIMG_4191.jpgIMG_4189.jpgIMG_4190.jpg
bigmike
354
Dixon CA.
Based on my CARC experience, I recommend you just touch up the peeled areas with CARC. There isn't much you can do about the periodic peeling except an occasional touch up. I'd do this over a total blast and paint.
Mos68x
36
Seligman,AZ
Most experience I have with CARC is the touch up kits we had in the military, but if were me in your shoes I'd just blast the entire cab to ensure there was no rust at all and then primer it with your choice of base. I'd certainly be interested to see how your cab turned out with the Linex on it too.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Do it once and forget about it. Drop it off at a blaster's place and let him prime it once hes done. Make sure its a good primer and let it gas-out for about a week. Paint it however you want and never worry again.
