Suitable sub batteries for MEP003
PaulbusMax
Fort Worth/Texas
So the other day i took a little road trip and picked up my MEP-003. Oddly, when i bid on it, the batteries were present, however when i arrived to get it, they were gone. Oh well. My question is, where does one procure this type of battery, and what is the consenus on which battery to use as a suitable substitute?
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
The originals are the 6TL's that the military uses a lot. However for the price, any good group 31 battery works really well. I used a pair of 1000 CCA Interstates for mine. Compared to the price of a 6TL, you can get both group 31's for the price of one 6TL sometimes.
NEIOWA
127
NE IOWA
You perhaps have a MEP-002 5kw? Two cylinder (single exhaust stack). The MEP002 uses 2TN size batteries. Get small car batteries.
The MEP003 uses 6TL batteries. GREAT batteries to my thinking.
kipman
15
Lancaster Ohio
My experience with 6tl batteries has been bad, help a guy who owns 100 military trucks, every 6tl that has sat is junk, we let interstate batteries sit for over a year and they come back.
glcaines
2,593
Hiawassee, Georgia
I used two Exide Orbital batteries. When I picked up my MEP-003A it didn't have 6TLs, it had two military Optima batteries, which were shot. All of the other MEP-003A gensets at Fort Jackson when I picked up also had Optimas installed, or at least the ones with batteries did. The Exides fit right in place, but were not quite as tall. I used Nylon spacers between the top of the battery brackets and the nuts on the verticle supports to take up the space. Be aware if you use Exide Orbitals you need to be careful installing the brackets so that you don't short out the positive poles on the batteries to ground.
PaulbusMax
Fort Worth/Texas
Definitely have a -003, and all the info on batteries is interesting to read. The likes, dislikes, etc. Got around to tinkering with the set yesterday, changed the oil and filter, fuel filters, checked the strainer. Removed the tank and flushed it. (yuk) Found grounding rods and a fuel tube clamped in the chassis, cool. I should be able to go for start next time i play with it.
