Super easy windshield wiper military to civilian on the cheap.
TOBASH
3,961
Brooklyn, NY
1- remove arm from vehicle.
2- remove blade from arm. Save screw and bolt!
3- grind off rivets that hold the blade receiver to the arm. [EDIT 05/28/2020 - just cut the arm immediately proximal to the closest rivet. Just cut it off and forget about all the grinding and smoothing. The arm will be a tad too long if you don't cut some off anyways, so make your life easier. Proceed to step 5 and skip step 4 if you cut as per this edit.]
4- smooth off the rivets
5- purchase Ansco 12 inch civilian wiper blades with included plastic adapter bits.
[EDIT- Anco 12 inch 31-12] [SKEW no. 37577 09449]
Wiper arm J adapter included with wiper blade.jpg Anco Wiper Box top.jpgAnco wiper Box back instructions.jpgAnco Skew.jpg
6- slide arm into the “J” shaped adapter that comes with civilian Ansco 12 inch wipers.
7- Drill through hole meant to be used for retainer clip. Drill through hole, through wiper arm, and all the way through underside plastic.
8- repurpose the screw and nylon bolt to anchor the “J” shapes adapter to the wiper arm.
9- attach the civilian wiper to the adapted military arm.
9a- Comparison of military (center) with modified wiper arms. Top shows modification with screw. Bottom is modified using modified rivet. (I modified rivet to fit the plastic "J" adapter as modification version 1, then realized that using screw and nylon nut is a easier and better option as modification version 2. )
[EDIT- Notice the Military blade and wiper arm are both a bit shorter. Makes no difference but if you want to center your wiper then cut off about 2/3 inch off your wiper arm and then mount the plastic "J" adapter to move the wiper blade into more of a military position. I just left mine alone as it does not rub or cause a problem on my rig.]
10- reattach to your HMMWV and enjoy $5-10 easy accessed replacements.
[EDIT- After you do this conversion you won't need to replace the entire civilian wiper blade/bracket assembly every time your wipers wear out. My auto parts place sells the 12 inch bare rubber wiper blades without bracket for 5 clams apiece. In the old days, you used to be able to buy just the blade itself, and that was common practice. Now the blades are usually sold with the included bracket because people are getting lazy. [I'm getting old and waxing nostalgic.] You now can still buy just a wiper rubber on Amaz0n or FleaBay. With this civilian modification you now have options.]
TOBASH
3,961
Brooklyn, NY
Pics of the final product?
P/N of 12” blades?
I had issues with trying to upload from my iPhone. Instead I transferred images to my computer. All that delayed picture upload.
These parts come in almost all civilian wiper blade boxes, but we usually just throw them out. The "J" adapter is just one of the little plastic adapter pieces we overlook and throw out.
Later tonight I will try to upload pics of the box that the wipers and adapter parts came in. All this stuff comes free with the wipers, so this is a super cheap conversion.
T
dmetalmiki
2,036
London England
Thank you for an excellent and informative post.
The 'Apprentices' are duly carrying out your modification as we speak, So to speak!.
59
9
kingston/ NH
I did this modification yesterday, with the arm was still mounted, but a piece of plywood protecting the glass. Started grinding the rivets, but once I got them smooth, they were being stubborn. Then while holding up the new wiper, I decided, just cutting off the old bracket at the end of the arm would work better. As Tobash mentioned, this position the wiper better anyway. Quick work for the HF 3” air cutter and then 8930915D-ABDE-408D-BD38-87018761EAD5.jpegdrilling a new hole. All total, 10 minutes I have the new wiper installed.
My main reason, even after new stock blades, I was not getting even blade pressure. This new style is much better and will make change easy in the future.01291B03-0C71-4924-BF09-945EB607CF6E.jpeg
