Super-Single spare tire swing/gate mount!
VPed
307
Clint, TX
If you are asking me, no. I slotted the front keyhole slot further outboard and used the "wrong" end of the rear keyhole. Like this:
VPed
307
Clint, TX
Spacing is a good solution, I just had not thought or heard of doing it that way when I did mine. I would have needed to buy or otherwise obtain 3 inch channel.
XchaosX
Sherburne, NY
I just spaced mine out 3/4 from the frame. I didn't have to elongate the slot but did use the "wrong" end with a washer like you did.
Remm
Tucson,AZ
I have been working on a spare tire holder for my A3, I took the hummer mount design and up sized everything of course. Not only does it swing out but it swings down to ground by means of a air ram. When tire is in up position there is a lock/ stop to support it just in case the ram has a problem or air line. Bearing are the key to it I used spindles for J.D. disk easy to get and cheap. still working on valving tire goes up to fast need to change valving, a little geometry on ram and find a heavy duty swivel for air line when swinging out. will post pics as soon as work gives me some spare time to finish.
