Super singles are done, But....
marksgarage2
Southampton, NJ
Well the hubs are flipped and the 11.00-20s are on, but I am not real crazy about how it looks in the back. I like how the front looks. It steers and drives alot nicer though. O well I will run it like that for a while to see if I like it. How about m135 rims in the front and m35 rims in the rear? Here is some pics.
1,806
I'm not a big fan of the appearance of the singled out deuce with skinny tires. I know they are much better off road for sure but thats just me!
M1075
Oklahoma City
With paint like that and your bridge plate, how can it look bad? I like it. You can always use some different wheels or tires.
BFR
Rocket Surgeon
2,331
North Georgia
I think those look terrible 8) ... want to sell them?
I like them, but they would look better under my truck :)
YoungBill
5 ton super singles
I have seen some supers singles on hub and look like they have not been reversed. I saw one that someone in the Tired Iron club in TN bought and it looked like the hubs were not reveres but it had super singles.
Adamlee
Alexandria, VA
Super singles 12.5 on stock rims picture
red devils dude said:
YoungBill said:
Here is a picture of my M35 with 12.5 XLx mounted on stock rims without the hubs reserved.
hard on the bearings.
is it really hard on the bearings? i'd like to hear from others on this.
i can understand it if it were putting wrong offset wheels and tires on a semi-floating bearing, but is the load really going to wear these bearings out?
YoungBill
angle mount with the circle
The angled mount is for the NBC detector device. It sat on top of the platform and then plugged into the reader in the cab. It was to detect nuclear, biological and chemical warfare agents.
Will the set up really affect the wear on the bearings? I don't load it much but to haul a few cords of wood in the fall.
Thanks, Bill
FSBruva
Marietta, GA
We sort of started to cover this. "Hard on the bearings" implies that more force is being placed on the inner bearings, because of the perpendicular distance the tire is from the bearing. However, there is only 1" difference between the tire's position (as compared to the furthest bearing) for the rears as is stock for the front. Granted, several thousand pounds of force offset by an inch results in several hundred more pounds of pressure from the moment increase - but think of the crazy loads and stresses put on the bearings by driving fully loaded offroad with a 30 degree horizontal slope!! As gerhard mentioned in another thread: old grease, moisture or grit are far more likely to do damage to the bearings.
Mark - Part of the reason the back looks wierd is because the box is too wide, or looks that way. That's why the M135 and M34 beds are 88" wide - they line up with the running boards of the truck.
Matt
Stretch44875
Super Jr. Moderator
29
Tiro, Ohio
How about useing the M135 rims, as the outer wheel on the back axle, without flipping the hubs? Would be the same thing YoungBill's truck, just using M135 rims. Should move the tire closer to the center of the bearings, and wouldn't narrow the rear track as much as flipping the hubs.
Dennis
marksgarage2
Southampton, NJ
Well after putting 50 miles on the truck over the weekend, I am getting used to it. Acceleration, top speed, steering and overall ride and handling are all greatly improved. I will keep it like this for a while till the next bright idea comes along! Mark
DoubleDeuces
I have had a SuperSingle deuce and really liked it,but always felt the 11:00X20s slid alot, but YoungBill's 12.5s are the ticket. If you can run 12.5X20s on the standard rim,what would 14.00X20s look like and would there be a clearence problem? Bruce
