Surplus Tach wiring help
badgmc56
Southington Ct.
Looks to me that - signal terminal is hooked up to the negative side of the coil. Where did you find it? I have been looking for a 24 volt tach myself. My gasser has a reb- shift kit and a tach would be very helpful in shifting.
Barrman
2,188
Giddings, Texas
Great, thanks!
Umm, that means it is a V8 diesel tach and probably not going to work on my I6 Gasser. I will look it up and see if I can even hook it up. If I can get a reading, then I will worry about accuracy.
Lets see, a V8 sends 4 pulses per crankshaft revolution while a 6 sends 3 pulses per rev. Which will make the tach 25% slow, right? It will match the 12% slow speedo. I need to make up little placards like airplanes have next to the compass and air speed indicators showing the conversions to make them accurate. I will be so busy doing math in my head, I will never get bored while driving.
aboonski
West Melbourne Florida
I recently bought one just like Barrman has on Ebay - NOS. When you look at the wiring schematic for the Humvee, there are six (6) terminals on the Hummer tach vs. four (4) for the tach we have. Also, I have been told the Humvee tach has a black indicator needle where mine is red. The lamp wiring is separate from the screw terminals and is merely a red & black wire that attaches to the lamp itself. The person I bought the tach from indicated it might fit an LMTV dump truck? What is that? I think the wiring for this is quite simple requiring a pulse generator from a 6.2 Humvee motor; unfortunately if I install that in my CUCV I will not have a vacuum pump to shift my transmission. I know I posted pictures on other threads but wanted people to know that the person I bought mine from has others and is also a member of Steel Soldiers. His user name is aarron81. I was happy to have seen this thread because of the photo with the wiring sticker on the back. Mine was covered up with the mounting bracket - when I pulled that off, I got to see the wiring order for the first time.
