Survival 109 build
QUADJEEPER
Winter Springs, FL
Today pulled all of the wood flooring up. Expected a lot of rust, wasn't disappointed. Heavy rust and many holes in the back as well as heavy rust in the front. Center between the wheel wells was the best condition. Still have about half of the bolts to remove. Then I will Ospho treat the rust and patch the holes. Next will be insulation and plywood.
Another Ahab
4,844
Alexandria, VA
You got a major piece of labor out of the way there, QUADJEEPER; I know that was a lot of work.
It's hard to tell, but was the flooring some kind of tongue-and-groove 5/4 stock laying directly on the metal sheet pan (i.e., no sleepers)?
And was it bolted down? Or are those studs of some kind?
Another Ahab
4,844
Alexandria, VA
That was some major labor you got done there QUDJEEPER; and I know that was no piece of cake.
It's hard to tell, but is the flooring some kind of tongue-and-groove 5/4 stock layed directly on the sheet metal pan (i.e., no sleepers)?
QUADJEEPER
Winter Springs, FL
Was a lot of work. Tongue & groove 1+ inch oak boards. Very dense wood. Carriage bolts through the crossmembers under the sheet metal sub floor. Wood was directly on the rust, er, metal subfloor.
Another Ahab
4,844
Alexandria, VA
That must have been a nightmare busting those boards off of the carriage bolts (looks like they're about 6" on center).
I wouldn't even want to think about messing with all that.
Jeepsinker
470
Dry Creek, Louisiana
I heard once that these trucks were only built to last a month on the battlefield. I know for fact that they were built quickly and cheaply. If it was something they deemed important to last they would have made it from stainless. It is just a lucky side effect that our trucks last as long as they have and do.
rustystud
3,374
Woodinville, Washington
Makes sense.
Mike929
22
DFW, Tx
That wouldn't be very good for my moral if I was manning one of these trucks and knew the military didn't think the truck would last more then a month on the battlefield.
Mike929
22
DFW, Tx
I plan to start turning my 109 box into an off road RV. What do you plan to do with the floor?
I need to figure it out myself, just know I want a solid foundation if I am going to spend time and money building it out.
rustystud
3,374
When I was in the Marines as a tanker, I was told our life expectancy in combat was 5 minutes ! That's why tanks always travel with a unit of ground troops. Their there to protect the tank, not the tank to protect them.
61sleepercab
Walton, West Virginia
I always heard that troops want in the tank while the tankers want outside. Local veteran was a tanker when his tank disappeared in a German house basement when he pulled into the house to hide his tank. He ordered everyone out and pulled the pin on a grenade to put his tank out of its misery, his commander said no and you will walk the rest of the war. Grenade down the hatch, and he finished the war on foot. Mark
QUADJEEPER
Winter Springs, FL
Will be using Ospho rust treatment on the solid rusty metal, replacing the rotted out metal, insulating it then using plywood.
Another Ahab
4,844
Alexandria, VA
That's a real morale booster, right there:
Doctor: I have some good news and bad news.
Patient: Ok, well... Give me the good news first.
Doctor: You have 24-Hours to live.
Patient: How is that good news?!? So what's the bad news??
Doctor: I've been trying to call you since yesterday.
Clay James
Reno/NV
I remember doing that floor job on mine in the blistering heat of July after I had pulled all the inner walls and insulation out. Of everything I've done on my 109, that job sucked the most! But it had to be done and I'm glad it's done. I used POR15 all around the bottom of the box and 1" plywood that I coated the underneath with roof sealer for the floor. I'd like to somehow insulate the floor as it gets COLD in the winter.
Another Ahab
4,844
Alexandria, VA
You know, there is some kind of insulated structural material that's used in post-and-beam construction for roofing. It might work for this application. Because you're right: a cold floor kills all sense of comfort, even if the air temp in the space is toasty.
I'll see if I can't find something about that, and post it up.
Another Ahab
4,844
Alexandria, VA
You know there is some kind of insulated structural material that's used in post-and-beam construction for roofing. It might work for this application. Because you're right:a cold floor kills all sense of comfort, even if the air temp in the space is toasty.
I found a place to start. It might not be exactly the best solution to the problem, but maybe you can get some ideas from the concept.
The product is called an "Insulated Panel System"
