Another Ahab
- 4,943
- 113
- Alexandria, VA
No, standard stock unfinished 18" unit from Lowes.It all looks real good, and totally ship-shape; nice work.
That 3-drawer cabinet looks custom (being so narrow). Did you knock that up yourself?
Thanks, but a very dim light. Lots to do before the Oct. Rally! Finish bathroom, finish cab pass through door, make a table, make an under sink kitchen cabinet, trim out the interior woodwork, find a spot for my grey water tank, fresh water plumbing and hot water heater, convert the brakes to dual circuit and add larger A3 wheel cylinders, get the rear frame extension welded on, build the enclosed deck for the rear, motorcycle rack, list goes on and on. Ugg.Looks like your starting to see the light at the end of the tunnel , nice work !
About 300# with racks, I need the weight in front, too much in the rear already.With them full that's going to be a lot of weight up there.
Will be max of 195# on the left side, less on the right. My 200# on the fender doesn't seem to be an issue. Did think of bracing them though. Not sure yet on that.It's a "survival build" not meant to be pretty, put them wherever works best for you . I do agree with above statement though , not sure if those fenders will hold up under the weight . Keep up the good work !
I've thought of that and seen it done, but already adding 4 feet to the rear of the truck, any more and won't be able to make the turn out of my back yard.I would say get bumper extensions and build a shelf between the front bumper and grill for them.
Cab over bunk in the future, so that won't work.Only because you asked, I looks dorky. But in a military vehicle looks don't count we are after function. Have you thought about a rack over the cab? I personalty like the bumper extension idea if you could still get into your yard.
I have really enjoyed your build thread, your work is impressive.
That's surly a better use of the space.Cab over bunk in the future, so that won't work.
With my luck they would leak into the fuel tanks!Could mount a few over the spare tire and fuel tank
See previous reply, planning on a cab over for extra bunk space in the future. Plus not wanting to add that much weight up high. Even the approx. 240# of solar panels on the roof was noticeable on the road.The issue of the Jerry Cans brings up images of WWII North Africa.
Wonder if the there's a way to rack them up over the cab? Would it work for you?
Maybe stow them up there empty for a photo to see how THAT looks, just to compare one set-up over another (it's tough because you never really know until you actually see it, you know?).
