SVO vs WVO vs BD single and dual tank systems
HillBilly
Bethany WV
Dual tank
Bjorn I found another thread on SS about auxiliary fuel tanks that list US sites for duel tank svo/wvo conversion.
http://www.greasecar.com/index.cfm
http://frybrid.com/
Hope this helps! Once I have my M1031 up and runin I am goin with the duel tank system. My POV 2cents this would be the best way for running svo/wvo. These systems use the waist heat from the engine to bring the temp up to 160 or more eliminating the need fo special inj., IP, and GP's. On a more personal note I like the frybrid kits, the option of having a custom tank built for the 1031 and the fact that they ensure the oil, not just the engine is at least 160 Deg. before switchover.
HillBilly
bruno_rs
chester, nj
RE: Dual tank
hey guys, i have a 1008 and 1009. i'd like to install a wvo system on both. are you already set up to run wvo? if so what system are you running and how much did it set you back? where are you getting your wvo from? thanks, looking forward to hearing from you. have a good one.
