sway bar bushing installation
lindyp38
ulster county ny
ill be posting pics soon.......the bushings seem to big for sway bar.....the local shop could not press them in....
any help would be appreciated.....
cpf240
Free in Northern Idaho
Someone mentioned before that the "correct" bushings don't fit, and so they used the poly two-part bushings. Another person suggested putting the bushings in the freezer for a while to cause the rubber to contract a bit, and then try pressing them in. There was also a mention of taking the metal sleeve out first, then press in the rubber portion, and then reinsert the metal sleeve.
I'd love to hear how this goes, as I have the same bushings sitting in a box awaiting time for installation.
cpf240
Sorry, I don't have any numbers for the poly bushings. I've had too many issues in the past with squeaky poly bushings on other cars, so am hoping to avoid them.
319
Lieutenant
49
Michigan
In my experience, the one piece bushings could not be pressed in by me, or a professional shop. Freezing doesn't work, boiling doesn't work, removing the sleeve doesn't work. What worked is the two piece bushings. Got them from O'Reillys. I'll find the receipt and post the part number.
jw4x4
Dayton, Ohio
1,168
I posted that link because that's what comes up with a search for what 319 posted. (ens 3.5118g)
Miah
29
Kansas City-ish, MO
I installed the LMC 34-0114 (73-80 w/ grease-able brackets) while doing a front axle swap. Went fairly well except the front brackets didn't have quite wide enough bolt holes for the stock bolts. Took a wee bit of grinding to solve the issue. Believe the 34-116(w/o brackets) is the proper part # tho. If these give me any grief I'll swap out to the other set & back to the stock brackets.
lindyp38
ulster county ny
i went thru summit racing......bushings were in two pieces....and went in very easily.........thanks to all for ur help.....
the summit racing bushings came in a kit...
