Sway Bar Extensions
Sharecropper
963
Paris KY
Off Road Design offers a kit for that. Not trying to tell you what to do, but I removed my sway bar and threw it in the dumpster.
WildMike
Illinois
Does anyone know where I can get extensions for this type of setup? I’ve looked but only see the other types. It bolts to the leaf spring u-bolt plate, but now it’s about 2” away from bolting to the frame. Any suggestions?
I ordered the kit from Off Road Design and works great. Can easily disconnect for offroad flex, also never thought about springs moving forward and back fighting sway bar. This kit allows forward/backward movement.
Was $100 i have a 6" lift on 35" tires, daily driver. So need to keep sway down much as possible!
Added picture for you from online.
JoeJoe_91
29
Melrose, FL
Hell yeah, I ended up finding that same one months ago. I have a 6” lift as well as 35s, I love this truck!!! She’s a work in progress.
Sharecropper
963
Paris KY
Cross-over steering and a sway bar will not work together. So I took my sway bar off and threw it away. Zero problems and much more articulation.
Mad Texan
1,150
Chester County, PA
ORD has come up with a resolution for that... with a M1008 it's probably less of an issue. I have one being delivered Monday or Tuesday... :)
