acme66
- 7
- 0
- Plains, Montana
I am getting intermittent power loss. Sometimes I go days between episodes. Trust me when I say I have checked and eliminated all the easy stuff. Solenoid, tank, filter, lines, contamination you name it. I am either down to something like a plastic bag that drifts over an sometimes blocks the pickup or a lift pump that is failing intermittently. I have checked that tank and it looks like a stainless steel bowl. I fished around in it with barbed wire and a spring grabber but have come up with nothing. Once in the middle of an episode I put air to the tank and could only get a dribble out at 3psi of air pressure. But then I pull the pickup tube and.... nothing. All the lines are copper and clear. I haven't run wire through them but they blow out. Like I said I have been through every component and have found no faults. Now I am starting to doubt myself and the time I pressured the tank and wondering if it could have been the pump the whole time. Every one of the mechanics I have talked to feels that if the pump is failing then it fails. Loss of pressure and loss of power. None of this on and off stuff. Anyone here have a lift pump fail and come back then fail again running normally between times? Serious question because I am getting a little crazy out here.
Ken
Ken
