Synthetic lube efficiency report
Wingnut13
562
Strafford, NH
I ran across this test conducted on FMTV's for the Army. I searched around to see if someone has posted this before, didn't find it. Forgive me if it has been discussed before. It's nice to see some real numbers and not just speculation of synthetic oils vs what Army likes to run. To save you the read I'll post below the down and dirty summary.
Link to the test. https://apps.dtic.mil/sti/pdfs/ADA622985.pdf
And the summary
An evaluation of fuel consumption using three FMTVs showed the potential for significant improvement using advanced lubricants. For the engine and transmission, the baseline OE/HDO- 15/40 oil was replaced with a candidate Single Common Powertrain Lubricant (SCPL). The GO- 80/90 baseline for the axles was replaced with synthetic SAE 75W-90 oil selected by TARDEC. Over a two-speed highway cycle, an average improvement of 6.1% was observed. When operated on a cycle which included stationary idle and transients, the average fuel consumption improvement increased to 7.8%.
Seems like a less expensive way to increase milage over gear swaps, or will help those who already have done them to get even better milage.
~Wingnut
Skyhawk13205
253
Alaska
And the summary
~Wingnut
Thanks for finding that. I have always wondered why cars are using lighter oil. My guess is most automotive industries are using lighter oils in their cars and trucks to gain higher fuel efficiency.
looks like the engine and transmission oils they went down to 0w-20. It makes since since it is easier to spool a lighter weight fluids than heavier one.
For transmission that is prob fine since TES 295 is at a 0w-20 but the engine viscosity for direct and precombustion engines recommended is 0w-30 for ambient temps of -40F to 86F
I have attached some pics of fluid recommendation from CAT and Allison from my internet research. All data is considered uncontrolled and outdated.
