me too, along with every other brand that ends up in the back of my truck!I run my M35A2 on Mobil 1 WMO.
I guess I do to.me too, along with every other brand that ends up in the back of my truck!
Thanks for the link to my forum. If you want to run WMO, then you might want to look at this section of the Beyond Biodiesel forum Making Black Diesel (WMO)So after reading this reply I found this thread on another forum: http://beyondbiodiesel.org/forum/index.php?topic=140.0
Hey I've sean that mug shot before!
Your plan of starting with 10% WMO seems like a good plan. I started at 80% blended, settled, filtered and centrifuged WMO and worked my way down to 20%. I found the less WMO I put into my 6.2DD the longer it took for my injectors to coke shut. At 20% it took 3 months. At that point it did not seem worth it. Now I am working on distilling it. Burning distilled WMO in the same engine has not coked my injectors yet.So once I sell my car I plan to run the M1009 as a daily driver for as long as possible. I don't have the house in Raleigh yet so I'm not sure about my actual commute but I think I'm going to be running about 60 miles per day and maybe a bit more. I want to save as much as possible and reuse as much as possible so WMO seems like a good alternative with a home grown filtration system to prep it. Now I'm thinking that most of the people doing this on SS are probably running true multi-fuel engines so I might be out of luck.
Since this is a DD I don't really want to have to pull it down once a week to clean the injectors and I certainly don't want to get stuck on the side of the road. The wife would lose faith in my 'experiment' very quickly if she had to come get me and tow the old truck home.
On the other hand, it looks like it may be possible to start with a very low WMO blend of 90/10 and very slowly work my way up, running a full tank of straight diesel every 3rd tank and pulling the injectors every weekend to check them out until everything stabilizes. This is what I have gleaned from looking around, not a plan I saw anywhere else. I've seen people discussing running 60/40 D2/WMO and that would be a significant fuel savings as long as it wasn't offset with an occasional towing bill or an hour along the side of the road with a bottle of acetone cleaning my injectors twice a month... BTW, no turbo on the truck.
Thoughts?
how much energy are you using towards distilling the oil? what temp does it evaporate? how much can you do at a time? just curious.Thanks for the link to my forum. If you want to run WMO, then you might want to look at this section of the Beyond Biodiesel forum Making Black Diesel (WMO)
very interesting ive done some ethanol distilling before, curious as to what is needed to do waste oil obviously the heat is much higher. if you dont mind id be very interested in your setup.I process 5-gallon batches of WMO, to get 4.5 gallons of distillate. It takes 1500watts, and 4 hours at 800F.
Oh, yeah. It is on the shopping list.i do believe its time for you to get a deuce!
