T/M question for cucv's
tourus
madison me.
I need to know which of the t/m I can look in to be able to read and print off how to remove and install the IP pump on our 6.2 diesels. it is for the guys at work we have a couple and I think the split the pump in the wrong place they got the pump off with taking the 3 bolts out of the front gear. (don't ask I don't know did not see it just was told about it) .... I want to print off the section and give it to them
thanks
Warthog
232
OKC, OK
Easy to search the manual and find it. Took me 30 seconds. Searched for fuel in the table of contents.
TM 9-2320-289-34, Section 3-37, page 3-119
m38inmaine
57
Maine USA
To remove the pump the 3 nuts on the engine side need to come off and the 3 bolts on the radiator side which are reached through the oil fill tube hole. I use a magnet through the center of the socket to remove the bolts, don't want to loose one down in the front engine cover.
