T138 transfer case recommended oil ?
zxmedic
Canada
Hi guys I've tried the search and no luck tried oil change , oil etc etc no find ..
What are you guys using for oil I have the Rockwell service manual here and it clearly states to only use GL 1 90 weight oil which is a mineral base and to not use higher gl rated oils as they are not mineral based . Has anyone found a proper substitute
