Walt4653
- 0
- 0
- Lincoln RI
![Very Happy :-D :-D](https://www.steelsoldiers.com/images/smilies/icon_biggrin.gif)
cost was about $89.00. Well worth it. Also is backlighted and has built in hr gauge digital.
great addition and right in the money
company name is tiny tach on the web
Hi, might be interested if you want to know if your gen is running at specified hertz, 60 cycles , most of the gauges on the gensets are off several hertz, I picked up a TINY TACH WITH 1/4" receiver that goes on fuel line, ran wires through control box and flush mounted it.. BE ADVISED IT RUNS ON 12 VOLTS AND WILL BURN OUT, PERCHASED A 24-12 v ADAPTER ON EBAY, BE CAREFUL 80% coming from china and you might not get what you ordered, ordered off USA site delivered within 5 days. Now I can safely run tv and other elect stuff without blowing them.
Walt, isn't it easier to just measure the frequency with a kill-a-watt or a Hz meter?Hi, might be interested if you want to know if your gen is running at specified hertz, 60 cycles , most of the gauges on the gensets are off several hertz, I picked up a TINY TACH WITH 1/4" receiver that goes on fuel line, ran wires through control box and flush mounted it.. BE ADVISED IT RUNS ON 12 VOLTS AND WILL BURN OUT, PERCHASED A 24-12 v ADAPTER ON EBAY, BE CAREFUL 80% coming from china and you might not get what you ordered, ordered off USA site delivered within 5 days. Now I can safely run tv and other elect stuff without blowing them.
