- 724
- 138
- 43
- Gainesville, Florida
Hi all.
I want to swap a nicer tailgate from a junker HMMWV to my running M1114. Both trucks have similar tailgates with hinges bolted to the frame. Two of the bolts and nuts on each side are easy to access. The third's nut is covered by body a bushing and blocked by angled metal. Feeling around it seems like the body bushing needs to be removed to access the last nut.
Would removing the hinge pin be easier? I'm assuming it's removed just like a hinge pin on a house door. Are these pins reuseable or will I need to replace it?
