Tapatalk issue
4,805
It's listed simply as steel soldiers. However, what network were you connecting with? What is your web facing IP address?
quickfarms
25
Orange Junction, CA
I am using verizon on a iPhone 5s with the current operating system.
what is a web facing IP address?
i hope this helps.
i use tapatalk for two other forums and they are working just fine.
1,178
How are you posting in this thread?
flashgordon
Southwest, NM
I am using Iphone 5 on verizon also. Tapatalk aint working here either. Of course with all the daily festivities, I probably wont have time to experiment. When you find a cure, Post it..
-FLASH-
4,805
I had an issue all day yesterday as well
-FLASH-
The only way you'll cure it is if you send me your web facing IP address. Otherwise you'll not be able to use tapatalk.
blybrook
Fairbanks, AK
Tapatalk had an update yesterday (12/24) that was giving me problems as well on several forums. Shutting down tapatalk and rebooting the phone (iphone 5 w/ 7.0.4 on att) reset something and all is working now without issue. You will likely have to re-login to your forums, but it should work without the immediate crashing that was occurring.
It is not the fault of SS or the forums themselves, it is an app issue.
Thanks go to the admin here that are trying to assist in getting it working again for the users.
Merry Christmas.
4,805
If it's an issue with connecting at all, there's a possibility that security system I've implemented might be blocking it. But if it's just slow, I have zero control over cell coverage, data speeds, device speeds, exc.
Mercunimog404
Banned
352
Carson City/Nevada
I understand. It's not this site. It's all of them i go on. Oh well. Keep up the good work.
