Tatra 813 vs MAN Kat1 10t
Henrik74
Sweden
Hi
I’m into buying a Tatra 813 or a MAN Kat1 8x8 but can’t decide witch
I’m going to use it on the road and a bit off-road a want a truck that is nice to drive I have a Scania SBAT111s to day great truck but to small cabin need to go 3 in the cabin.
I know this is the Tatra forum but some one whit some input??
Best Regards
Henrik
T815-8x8
Bozman MT
Think you would need to compare the MAN to the T815 series, if its just versus 813, then I would have to say go with the MAN KAt1
Henrik74
Sweden
Hi
Thanks for your answer.
I'm just back from Berlin with a Tatra 813 better price and a better cabin (size) then the MAN Kat1.
Very happy with the truck so far, had some problem with the diesel filter under the drive home auronde 1000 miles drive ;)
duncan
Netherlands
Dont buy MAN for offroading. MAN is nice for high speed "semi offroad" / "unpaved", but its not an offroad vehicle. Tatra is. Then, a MAN 4x4 uses the same amount of diesel as a Tatra 813 8x8. Tatra has the 7-seat 4 door cab, MAN has a 4-seat 2 door cab. Spare parts for Tatra are a lot cheaper too. Tatra T815 is a "luxury" version of the T813, but (on the 8x8) due to a longer wheelbase slightly less capable offroad (too much space between 2nd and 3rd axle).
You'll be happy with your 813, good choice.
Henrik74
Sweden
So did you buy a Kolos 4 door version
Yes the 813 kolos
The truck is works great but have some question on the ventils on the fuel tanks, ventil up open or down open? The bigger one return pipe ,small to the fuel pump?. I have 3 on the left tank that has no ventil is that to the heater?
Do any no were I can get the English Handbook and the workshop manual?
The truck will be repainted not sure which color, it has been at a towing company in Berlin in theres garage for 5 years not in use and under 11 years only been used very little.
Here is a picture.
Henrik
T815-8x8
Bozman MT
Line from tank to fuel filter will be the supply feed, tank valve position I do not know which way, Duncan will know, you can disconnect to check.
I have drivers manual, workshop repair, and parts books in English.
I will not be home until June 10th, that's the earliest I could send them, also why I cannot answer valve position
Henrik74
Sweden
If you could send me that it would be great!! June the 10th is faster then if I would try to learn german ;
duncan
Netherlands
On the valves: up is open, down closed. Use only one tank at a time and open both feed and return valve on the same side, otherwise you will pump fuel between the tanks. Left tank has an extra fuel return line without a valve, this is the overflow from the injectors.
The truck looks like it's in good shape, nice find!
Henrik74
Sweden
Ok thanks Duncan.
Yes the truck is in good shape, its rust free.
It has some electric things that I must figure out but nothing bigg.
Henrik74
Sweden
Picked up this weekend, is a long-term project. The idea is to mount it in the back of Tatran and decorate it for short term accommodation.
It is a Swedish Stab Cab.
1,5 year and also wants to drive Tatra ;)
Carlo
palazzago italia
Well I have had both. The 813 kolos was sold 2 years ago but I still have my Man KAT 5 ton. The difference is like night and day between the to! The 813 is crude and I mean crude. Parts are cheap when you find them and you will need to find a source for they do break, BUT the MAN KAT just goes and goes. The Deutz V8 diesel starts, runs and cant over heat with its air cooling. The MAN is just high high quality and you feel it when you drive it.
T815-8x8
Bozman MT
Thank Duncan,
Carlos, to be far that's comparing 2 different decades of truck DESIGN, I know 813 spanned into the early 80's but its design is mid 60's with very few changes, I'll conceded that German build quality is the best but the put 815 to KAT1 and the balance is a lot closer except in offroad performance where it's hand down to Tatra. End of day one has to make decision on requirements etc
Carlo
palazzago italia
All I can clearly and honestly say I have owned and operated both. Parts are not as easy as they were to find and prices are 5 times higher in a short time. My 813 Passed more time waiting for parts than being used. I can go to my local Man dealer and he has the part tomorrow morning.
I must also add I am a retired Army major in the italian army armour. We spent years testing the 813 and 815 and found the build quality 3 world level. The US army even choose Man Kat's in Europe!
T815-8x8
Bozman MT
I'm not arguing 813, look at my YouTube videos from UK Mil DVD show 2007 back to back MAN 8x8 v T817 8x8 no comparison and offroad Trucktrials Tatra kicks everything out of its path hence why Navistar / Tatra ATV (T817) for the military
Henrik74
Sweden
Hi T815-8x8
I will take some pictures tomorrow when I am at work.
Will also give you some info then.
Regards Henrik
Henrik74
Sweden
Henrik, do you have any info' on these "Stab Cabs" I would like to see inside pics when you have time
Sorry I havent been to work until today. Have had some illness in the family.
Here are some pictures.
The back side whit twin doors
The front with some rack for cans and a Diesel generator Under the rack is the spare tyre supposed to be and some extras
Left side and right side looks the same
Inside
A lot of stuff;)
Comes whit a fuelburner heater.
This cabin has been installed with radio equipment.
