- 10,349
- 94
- 48
- Meadows of Dan, Virginia
There is one for each fuel tank, mounted on the frame accessible from the outside.......
So where does this mount on the XM757???? Is this in the cab somewhere handy?
The OT-64 utilizes one of the aircooled Tatra V-8's actually. Same type of internals though, all moving stuff on roller bearings.is the 912-2 the same engine as ont he ot-64?
Its 7 pieces that assemble into one. If you click on the repair manual link near the first part of this thread you can see some better pics. It's pretty much staked and bolted with some huge bolts then balanced. Its hollow too and both oil pumps pump oil through the crank through the front journal and lubricates the rods and mains then exits through a ball valve at the rear flange of the shaft.That is an interesting crank shaft. It is one piece?
Cool dealThere is one for each fuel tank, mounted on the frame accessible from the outside.
Using a thread as a log is what I do sometimes also.Thanks BjornI guess I'm keeping a sort of log on this thread
Let me know if you see something that I can improve please speak up! As you can see I'm doing some improvements.
....... Those little lights stay on all the time though when the lighting switch is open??????![]()
That.......is a fantastic idea my friend!Good luck with your mods - I am unfamiliar with the 912 motor, I know the 930 cools ok at idle and has a rather large cooler I know that quite a few in the CZ mount an aux cooler on the rear deck with a cage to protect it.
Try dynamat for insuation. We put in the red truck on my avatar and it cuts noise from teeth rattling to manageable. heat infiltration was cut dramtically as well. Even cheap marine high density insulation will work (check your local WestMarine)
Yep they are quite large, almost 300lbs per barrel.Yes, it was the one Earl had. Didn't drive it, but enjoyed the close inspection. The guns were a lot bigger than I expected. Too bad they were de-mil'ed, must be a ball to fire!
I like the camera idea, could be useful on a couple of my other vehicles, the M813 in particular. Good for backing a trailer too. With the M105 behind me, large as it is I can't see it at all unless it is way off track. The camera might help me limit the number of ungentlemany words that escape when I try to place the trailer.
Cheers
