Tec Tip of the Day
Floridianson
2,503
Interlachen Fl.
If you have a 250 Cummins pull one bolt at a time that holds the water pump an use Never-Seize on the threads. Replace and do another till all six are done. Bolt is 9/16 and there are six of them. You might thank me later.
Also this is the grease I use for the water pump.
Tow4
646
Orlando, FL
If one of those bolts break off, we might cuss you today!:doh:
Floridianson
2,503
Interlachen Fl.
Better to find out now in your yard than when your belt breaks on the road and you can't tighten the new belt up.
73m819
325
gainesville, ga.
I want to add to this, WHEN you have to pull the water pump for ANY REASON, use a good bit of GOOD anti-seize on the NEW gasket (ALWAYS REPLACE the WP gasket), other wise there is a VERY good chance that the copper gasket WILL GULL and LEAK when you adjust the belt over time.
