tell me about the MEP-501A
wsucougarx
Washington State
I was surprised how cheap they went for. While I was there I noticed the gov't fuel draining method. They cut all the fuel lines on these gennies!! Oh well, probably a good idea to replace the lines anyways. Was looking forward to firing them off when I got home. Looks like I'll have to do a little bit of work before I get to play with these things.
Artisan
229
CDA Idaho
What were they, a couple of Hundred each?
Shipping killed it for me.
Cut lines? No a big deal, look real hard for other abuse and fire them off!
Jealous! ;-)
wsucougarx
Washington State
Whew! Finally got one generator to fire off today. Took some time to bleed the fuel lines. Boy when she finally fired off, I thought there was an issue. There was nothing but a blinding white fog of diesel smoke that filled my area. It took her about 1 minute to go to a smooth idle. Once she was purged of air she just purred. What a great little generator. I'm awaiting a fuel filter before I can tackle my second generator. Hopefully she'll be as smooth as the first;-)
BrutusM37
Attleboro, MA
Sorry to revive an old thread...
I have a MEP-501a with only 2.4hrs and it runs like a champ. I was going to use it for battery charging but plans changed. Was trying to sell it but no one in my area wants a bizarre 28V DC gen. Does anyone know if I can directly connect a 24VDC to 120VAC inverter to the terminals and get conventional power out of it? I'm wondering if there needs to be a battery bank in the mix?
kloppk
4,102
Pepperell, Massachusetts
You need to run it through a battery bank to make the inverter happy.
Agreed.
A couple of 12v batteries in series would do the trick.
Generally 24 volt inverters will work with a 28 volt input. They usually are happy with ~20-32 volts depending on the make/model.
Be sure to check the inverters spec sheet to be sure!
BrutusM37
Attleboro, MA
I figured the batteries would be necessary. I already have a MEP-531a so I'm not going to bother investing in the parts to make this 501a a not so portable 120VAC unit. I really appreciate the replies, saved me a lot of time and money.
rustystud
3,374
Woodinville, Washington
Did you ever try and start your truck with this generator ? I also bought 2 of them at the same auction. They run great, but would love to have a MEP-531 instead. I want it for my Alaska Adventure. If I could figure out a cheap way of converting one to 120volts I would do it in a heart beat ! I haven't seen any more for sell lately. The only ones I've seen are from Green Mountain Generators and they want $1600.00 for it !
