Temp. sending unit location ???
Elohim1
36
Oxford, Ohio
My temp gauge is not working , I guess i will start by replacing the sending unit.
Where is this located and where can one be found??
Chris
cranetruck
94
Meadows of Dan, Virginia
It's located on the engine side near the t-stat housing. Check the wire/connector before replacing it, they are pretty rugged. Should be readily available.
jeepthrills
before you go replacing parts, you should really decide if your problem is the sender, the wiring or the gauge. It is easy as long as you have an OHM meter or a standard multi-tester. check resistance of the sender with a cold engine and with a warm engine( at least 15 mins of normal driving). If you have a definate differential in resistance, check the wiring. The values you got at the sender should the same as the ones @ the wiring which goes into the gauge +/- 5%. More that that and you may want to consider changing out the wires in the harness.
My suggestion is you yank the dash and measure the resistance across the wires (master switch on engine cold)
then measure resistance at sender
Go for a drive and get it nice and warm, then re check @ both places. If values are equal (warm and cold with a differential) then replace the gauge. If not equal its either the sender or the wiring.
just my [2cents]
Good luck!!
ironhorsethegeneral
11
Acworth, GA
The fastest way to check to see if guage works is to disconnect the wire at the sender and ground it on the engine block somewhere. Turn master on if needle swings right the guage is good if no movement guage or wire is bad. Good Luck!!
