scottgs
- 0
- 16
- Oak Ridge, TN
Typically, in an FM radio, if the unsquelched static volume is low, it's often an IF section problem. It could be detector (discriminator) or audio section too.
If you have test equipment, the way to tell is to connect to a signal generator and generate a very strong on frequency signal, and if the audio level is as loud as normal, but the static is weak when there's no signal, then it's the IF section. If it's still weak either way, then it's probably a detector/audio problem. Of course if this is an IF problem, the receiver's sensitivity (to weak signals) will be very poor.
You can substitute for the generator by just taking another working radio and transmitting close by, say a few yards away. Talk with a normal voice as you transmit, and if it comes out the bad radio weak, it's an audio problem. If it comes out the bad radio good and loud, it's probably an IF problem.
I'm not a PRC 25/77 expert, although I have repaired them. However, I have repaired far more than my fair share of FM transceivers in general.
Garret
Garret
