Thank you
dirtdiver
Wichita, Kansas
I've been a member of this site for about 4 years. I rarely post, mainly because I have spent most of my time perusing the vast amount of information and knowledge here. I finally got my 1009 up and running after an engine swap, with the ensuing nightmare of hooking it all back together. I had never done anything like this, as I am only a shadetree mechanic. Although I did all the labor myself, I cannot say I did it all myself. The advice, input, and knowledge shared by those who post here helped me through it all.
To all newbies and novice mechanics like myself: Spend time reading and searching. Clean everything electrical. Replace anything rubber. Learn to use a voltmeter. The technical manuals are full of good info; download them and study.
This post is to simply say "thank you". Cheers!
Scar59
41
Mt. Eden, KY
Good for you. It's hard to explain the satisfaction one gets when you accomplish a complicated mechanical repair/task. Time spent reviewing the manuals and understanding the tools needed to accomplish a job is time well spent. Tribal knowledge is only as good as someone else's success/failures. Developing your own experience will only lead to further success. Ok, what else needs to be fixed now.....
JC
1,807
Where this is so helpful is the next time you have any issues, you can visualize what you worked on in your head to help figure out the issue.
