Thanks Again Bjorn!
dabtl
Denton, Texas
Your posts on electrical glitches and fixes are wonderful.
My latest deuce was loaded with them. I started with an amputated trailer socket. Then worked over the lights, bad light switch. Turn signals were defective grounds. I actually got the the last bolt, in frustration, before they worked good as new.
My latest was intermittent starting. I went to the ground first. Then to the ignition switch, replaced it. Then to the starter button. Replaced it and wrapped two potential shorts in electrical tape. Fixed.
I am still working on the horn, but that will not be much.
Without your posts, I would have had no idea what to do.
Thanks again.
WildSide
Western NC
My turn! My turn! I have almost all of your same light woes, but instead of a horn issue (mine works great) I have a new wiring harness but CUT dash panel wires so the markings are all gone. I'll be working on that over the next week or two.
I have read most of your posts and responses so I think I have a good plan of attack.....
We'll see.
Thanks from me too Bjorn.
Ryan
dabtl
Denton, Texas
The one thing Bjorn does not tell you is patience. You learn to be a detective of shorts, grounds and such by patiently checking the circuits.
Follow the wiring diagrams, use the MultiMeter and good luck.
