Thanks for the add, finally picked up my 1990 M1037 looking forward to minting "THOR"
Pisquinii
Bethlehem/PA
Prestolite Protective Control Box, I 'd like to change it out to a​
Nartron S3. I have a question. It comes with the TSU and where do I install it. Is it under the black cap with the wires coming out of it near the no step stamp on the air intake
This is the picture of where I think the TSU would go.
NormB
Hampshire, TN
You’re welcome.
Besides the “NO ETHER IN HMMWVS” rule, another tip/practice you should adhere to is:
Disconnect battery ground before doing ANY electrical work.
That - very pricey - S3 box hates stray current and seems to self-immolate at the first opportunity, or at least its predecessors did.
Don’t take any chances.
Oh, and have fun.
Pisquinii
Bethlehem/PA
Plan on it! I am actully disconnecting battery to install keyed battery cut off, then install S3, new glowplugs, Ground kit then install new batteries, then try to start! lol
Pisquinii
Bethlehem/PA
M1037 REAR SPRING CHANGE? ANY ADVICE OR PARTS LIST?
I did some research and found out that the upper rear spring perch and the springs are different in a M1037. They are 1 turn taller. I am thinking I can just add M998 rear springs and a spacer and maybe new shocks and I will be fine. I'd like to keep it as stock as possible to change back if I ever wanted to.
Has anyone done this? Is there anything I am missing about this idea? I am assuming I only have to drop the bottom swing arm to make this change.
Any help would be awesome....Thank you in advance.
Pisquinii
Bethlehem/PA
IT LIVES! Thanks for all the help getting it running, changed all 8 glow plugs, installed new KDS and yellow stripe sender. Added ground kit, hooked up batteries, clicked on to wait...lasted longer this time....light off cranked for like half a turn and started right up!
Thank you again for all the help all!
