SasquatchSanta
- 18
- 0
- Northern Minnesota
I'm starting this thread so it will hopefully be a gathering point for information on the 265 Chrysler flathead.
I am NOT an authority on the 265 however, over the years, I've done some research on the 265 that could make it easier for others that go the 265 route. Corrections are welcome.
The 265, especially in a Canadian M37 offers an unnoticeable modification that will make the M37 into a vehicle that will easily pull 489 gears. Add a cam, zero balance and a few other internal goodies and you've got a 3,200 RPM, 65 MPH truck.
I'm told that installing the long block 265 (or 251) in an American M37 requires a Canadian radiator and special canadian front motor mount. Having said this, I'm also told the standard American radiator can be used by mounting it on the mounting housings forward mounting brackets.
Note: If anyone has any info on the specifics of the required front motor mount please advise.
I'm told the 251 and 265 flywheel has a different number of teeth than the 230 therefore care must be taken when matching starters. The 230, 251 and 265 flywheels all interchange.
The difference between the 251 and 265 is the crank, rods and cam. The 265 uses standard 251 pistons.
The 251 and 265 long block (25-1/4" long) engines use the same block though I'm told the original 265 was equipped with a full gally oil system.
My research indicates the following block numbers used exclusively for the 265:
(I assume these blocks had the full oil gallery) (This list needs to be verified)
1400929
1402429
1551229
870744
1402529
1115829
The following blocks were listed for both the 265 and 251:
(I do not know why these blocks are different. Perhaps they were for engines built before the release of the 265)
1400229
1138129
1115829
The 265 chrakshaft number is: 1400188
The following trucks offered the 265 engine:
1957, 58, 59 & 60 W500
1957, 58 & 59 D600
1957, 58, 59 & 60 D500
The big disagvantage of the 265 is the availability of crank, cam, and rods.
On another note ... For personal reasons, I've always wanted to build a 265 using a Spirfire head. The Spitfire head had "Spirfire" cast into the top and was used on the 251 Chrysler and Desoto engines. If anyone knows if there are any benefits associated with the Spitifre head please advise.
1400929
1402429
1551229
870744
1402529
1115829
1400229
1138129
1115829
1957, 58 & 59 D600
