The FFS thread…
Mogman
10,596
Papalote, TX
He is awesome.
Bottom line, the 10” rotor should fit tight. It is loose. It is wrong.
Axle is correct BUT rotor is wrong and went out of balance as it is not tight
I am sorry, I miss understood, I guess you meant to say the drive flange was OK, to me axle=half shaft
Mogman
10,596
Papalote, TX
At least now you have it figured out and have the resources to fix it(y)
What kind of symptoms did you have? I would think this would cause a high speed vibration
TOBASH
3,972
Brooklyn, NY
I developed a progressive wobble that became a rhythmic bumping that became a serious loud and uncomfortable thumping.
Afterwards I noticed a leaking inner boot.
The problem seems to be wrong slotted rotor with too large inner diameter.
TOBASH
3,972
Brooklyn, NY
And because of the original owner being a cheap moron… $1500 bucks later, parts are on their way!
FFS!
(I will keep these axles as trail ready emergency units. I’ll machine rings to make them fit properly then tack them into place with the flux core.)
Mogman
10,596
Papalote, TX
FFS!
You may want to trade/sell them, you cannot get those at AutoZone and I bet they are not cheap!!
TOBASH
3,972
Brooklyn, NY
They are expensive BUT i will rebuild and make fitment rings that I will tack weld in place to keep these as an emergency set for off the grid adventures.
TOBASH
3,972
Brooklyn, NY
Half shafts and rotors arrived BUT I got no time till next week.
FFS!
TOBASH
3,972
Brooklyn, NY
Got all the stuff. Temps here in NYC just dropped 15 degrees for the week.
FFS
TOBASH
3,972
Brooklyn, NY
New passenger-side axle is in. It is correct with wider flange.
The rotors turned out to be correct. Pictures were parallax error of some sort.
Long breaker-bar made torquing the 6 rotor side bolts easy. Use of torque wrench only at the end was less painful this way.
Driver-side rear axle next week.
