The Goat amazes me again and again
mutt_r
31
Lower Saxony, Germany
Today I wanted to wash and prepare the Goat for an event we have here next weekend. 1st start the Goat. Nothing happened. No instruments, no starter, absolutely nothing.
So I took my M151 and the jump start cable. The goat starts immediately. But the instruments still don't work, the light, turn signal and so on doesn't work. Unusual. Batteries measured with the multimeter, both OK.
Where should I start with my search to solve this issue? Has any of you ever had this problem?
Appreciating any clues. Thank you in advance and best regards
Richard
glcaines
2,471
Hiawassee, Georgia
When you start the goat with the cable to your M151, leave the cable connected. With the cable still connected, are your instruments, lights, etc functional? If so, I would suspect your batteries or a damaged cable. Just because you can measure the correct voltage with the multimeter, doesn't mean that one of your batteries isn't going open internally under load. With the cable still connected, if your lights and instruments are still dead, you must have a problem with an electrical connection. To make certain that each of your cables are good, you can take a jumper cable and parallel each cable connection on the goat. Sometimes a cable can fail internally and show no sign of damage. Good luck.
mutt_r
31
When I turn on the lights of the M561 while the jump cable is still connected to the M151, the instruments, lights and flasher are also not working. Will spend some time on looking for a damaged cable. Had a similar problem with the connection between tractor and carrier a few years ago. Finally a cable inside the connector was broken.
mutt_r
31
Many thanks for all your hints. Found the problem and the solution today. The bolt for grounding the battery cable on the passenger side was junk. Drilled a new hole, took a new bolt and washers. And finally the Goat started like yesterday. While there was a metric bolt used by a previous owner, it looked like a previous problem as well.
