- 1,338
- 1,914
- 113
- Las Vegas Nevada
I just got my m1123 home and I’m starting to get into it a little bit. Best things about it are, it runs really good and starts easy. Didn’t leak a drop of oil in the driveway overnight. Oil on dipstick is clean as well as the power steering fluid. I drove it around the block and I hit 40mph and it was noisy but it drove straight and transmission shifted great. underneath the desert sand that has accumulated over the years it shows no signs of wear.
The bad; brake light stays on the dash and fuel gauge doesn’t work both I was aware of before purchase. I found a big rock chip in windshield underneath the gov planet sticker. Transfer case shifter doesn’t hardly shift and it was in low when I got it. I will read thru the TM to see the proper procedure and make sure it’s not something I’m doing wrong. I don’t know if this is good or bad but I’m feeling a little cheated and when I looked at the batteries they looked small but new, like 2/21 new. They have 690 cca and the hold down was laying in the floor.
The ugliest thing so far is the tires. They are brand new with tits and all but the desert sun has caused some cracks and they need to be replaced at some point but that will probably be the last thing I do.
I would love to hear from others how buying something from a few pics and a couple of videos turned out. I think I did good and I would buy it again given a 2nd chance. Edit!! The ugliest thing is I bought this because my 14-year-old showed interest and wanted to fix it up and use it I am the one outside in 103° heat and he’s playing Xbox now that’s ugly
