The Humvee takes off on its own like if someone flipped the "After Burner" switch.
Tiwaz
65
Miami Beach
The problem is that going at a steady speed, say…. 30 mph without changing the pressure applied on the gas pedal, all of a sudden the truck (1151) behaves like if I floored the pedal, it even downshifts on it’s own and takes off, and if I keep the same pressure on the pedal, it reaches about 50 MPH (or more) and it stays there for 10-15 seconds and then it behaves like I removed the foot from the pedal all together and it goes back to normal.
It does this even at 50 MPH the only difference is that it does not downshifts but you still hear the engine revving up and the speed increases substantially.
Mogman
10,589
Papalote, TX
What gets me is the TPS controls the downshift, along with the programming in the TCM.
So how is the TPS creating WOT without the shaft moving and at the same time the internal gov/linkage fails do do its job creating the same WOT condition as the TPS :eek:
Or is the shaft actually moving.....
Mogman
10,589
Papalote, TX
I would inspect the linkage and cable and the accelerator pedal carefully.
Does there seem to be ANY other influence that could be a "precursor" to the event????
NDT
7,517
Camp Wood/LC, TX
See this scenario is why I was halfway serious about my "animal" remark, the electronic trans won't downshift if the injection pump went to WOT on it's own internally.
Autonomy_Lost
1,554
Pennsylvania
I beleive there is a switch on the accelerator pedal that is activated when the pedal goes "to the floor" and downshifts....maybe that switch is activiating early?
Tiwaz
65
Miami Beach
Nothing moving.... (no strange sound.... no mechanical force change at the pedal... no clues)
Tiwaz
65
Miami Beach
Very good question Mogman but the answer is "No", I have carefully examined the "conditions" in which this problem happens and there is no consistency... no "precursor", engine temp (cold or hot) is not a factor, slope (going up hill or down hill) is not a factor (Florida is so damn flat) speed is not a factor, I don't know how to create situations that are unique but maybe I'll try to drive in D instead of overdrive and see if that changes anything .
Tiwaz
65
Miami Beach
I visually inspected the engine compartment and the pedals area but did not see anything out of the ordinary
Tiwaz
65
Miami Beach
Silly question, have you inspected the throttle return spring next to the TPS, the one that pushes back on the accelerator cable? Should be a double wire spring.View attachment 935149
Hey Thunderbirds thanks a lot for the picture, it really helps A LOT to identify components in the engine compartment especially when you are not familiar with the name and location of engine components. I'll definitely be checking on that as soon as I get back to my Humvee. Thanks again
Tiwaz
65
Miami Beach
I didn't know about this switch but definitely worth taking a look at it because it would make sense that if that switch has an intermittent contact, it would provoke that reaction. Can you tell me more specifically where that switch is located....?
Mogman
10,589
Papalote, TX
I think the switch he talks about is only on the 3 speed, the TPS controls all throttle functions to the transmission.
REF
135
Porterville Calif
Could the torque converter be unlocking causing the engine to rev up / feels like a downshift ? Possible adj or replace the switch on the brake ?
