Rolling_Eudaimonia
- 2
- 0
- New York State
So where can I manual for the LDS-465-1A engines, I curious to see what are the differences between the LDT and LDS series engines, from the numbers it would appear the block is the same. That is to say both are 478CID and that means it must be fuel injector pump size, fuel injectors , cam shaft and so on that are different. If so it should be a relatively easy operation to make an LDT into a LDS engine.
