The mythical CUCV 4L80E swap
richingalveston
122
galveston/Texas
you need to move the pivot point of bottom shift linkage back. I had the same problem with mine. The bottom piece (the one that goes into the shift fork on the tranny) will bind in the shift fork and cause it not to shift to 1 and 2.
richingalveston
122
galveston/Texas
4l80e shift linkage move
here is the bracket I made to move mine. I bolted the bracket to the original hole that the linkage went through. I made it out of some scrap. I may make a better one in the future. the second hole is there because I did not get it in the right place the first time.
Dave87
Holland,Michigan
Ok yea i moved that back. i measured the fork on the 400 and the 4l80 to get how far back i needed to move it. it seems to move pretty free when i clime under the truck and move it by hand but when i get everything hooked up it doesn't work so good. the bar that comes off the lower link is in the 7 oclock position when in first gear and in the 3 oclock position when in park. i have a feeling its the block i made. ill have the girl friend shift it so i can put eyes on it while im under the truck. the spring and shift linkage look like they did before just back about two inches or so.
Dave87
Holland,Michigan
Ok just an update, I got the bugs mostly worked out. The truck doesnt seem to get any better highway mpg but it runs out nice. it doesnt sound like the motor wants to explode haha. still alittle high for my liking. the stand alone computer works flawlessly. i wanna thank Trueknight and richingalveston for the post and for the help, really good information. Again thank you all
WARWAG
Yea it locks up. i run down the road at about 70-75, that doesnt help.
If your running down the highway at 70-75 MPH and getting the same mileage as when you were running down the road at a lesser speed but at HIGH RPMS then and getting the "same" fuel economy then you are getting better Miles Per Gallon as you are going further per gallon. Try running at the same speed as you were before the 4l80E swap. That will give you an idea on your fuel economy. Trust me. If your running at a lower RPM then your getting better miles per gallon.
Dave87
Holland,Michigan
yea i can agree with that but the truck is pushing more air. theres no doubt at 65 the truck will do better. it already seems better in town but i dont drive it enough to really gauge in town driving. i mainly put the over drive tranny in to do the highway. i get 15mpg at 70-75 so im happy. i need to slow down to 65, i fear my heads are lifting. might just be in my head. im taking the truck on a trip again in september so ill try 65 to the U.P.
cliffyp
Brownsville, Texas
Stock truck at 55 is turning 2700 rpm's. Same truck with 4L80 at 75 is turning 2700 rpm's. Scale it back a bit and get the engine in the 2100-2200 rpm's and it will be a lot happier. I cruised my 1028 w/700r4 @ 65 and got combined 17 mpg. I never had a chance to do a road trip and see what mpg's I'd get at 65 sustained. Oh well.
brazengoat06
Tulsa, OK
maybe i missed this somewhere but specifically what torque converter did you use? or does a 4l80 converter bolt up to a 6.2 flywheel?
btw awesome writeup! im going this weekend to grab a 4l80 core!
True Knight
182
San Pedro, CA
Thanks. The transmission shop that rebuilt the 4L80 got me the appropriate converter. If I remember correctly the brand was "The converter shop" or something similar. You will want a converter designed for the diesel because the one for a gas engine will have a higher stall speed. GM did put 4L80's behind 6.2/6.5s so you should just be able to order the correct converter. Nothing special.
Have you decided what trans controller you're going to use? There are more options out there now.
brazengoat06
Tulsa, OK
At this point I think ill go with the TCI unit. I has the same features as the more expensive units but less $$$. Looks like itll run about $730 for everything on the controller side. Unless someone else has a better solution.
True Knight
182
San Pedro, CA
It does have a lot of features. Like paddle shift capability. Ha ha, we really need that in this beast! I do want to hook up a trans temp sensor tho.
