90Jimmy
- 5
- 18
- Southern Illinois
There it is...EMP problem solved....and no one will steal it or ask to borrow it.
Um....... which company?Now I see a certain company now makes a highly modified 4L80e. With two additional forward ratios! Ah, choices.
TCIUm....... which company?
Just so you and others will know, when I clicked on the link, my Norton Internet Security blocked a virus hack. You probably should take that link down. Just my 2 cents.TCI
http://www.tciauto.com/tc/6x-six-speed-gm-automatic-transmission-850hphtml/
Basically, it splits the lower ratios with the OD using slightly different ratios. The magic is in the valve body and control computer. Aside from the non-stock planetaries and valve body, it is a 4L80e. Ratios seem perfect for the 6.2 with 4.56:1 axles.
Now to get them to accept the idea it can be used with a NP205.
I did not need to get an electronic vehicle speed signal. The transmission knows how fast it’s spinning, and the transfer case has a mechanical speedo output for the gauge. The trans control computer only needs an ENGINE SPEED (RPM) signal and a throttle position signal. (And obviously the signals from the transmission itself.) Now if you wanted to use an electric speedometer then you would have to change some stuff to get the signal.My 6.2 is about to give up so I bought a 96 Surburban K2500 with a vortec 350 and 4L80e that I plan to swap in my M1008. I plan on using a painless harness and want to use the np208 transfer case (since the 32 spline passenger drop 241's are so hard to find). What is the best way to get the Output VSS for the trans from the 208? I've seen a Dakota digital converter that still lets you retain the mechanical speedo cable as well. Is this way to go or do you guys have any other ideas? Any help is greatly appreciated.
Thank you for sharing all the info about your swap and the reply about the VSS. I'm excited to get the swap going!I did not need to get an electronic vehicle speed signal. The transmission knows how fast it’s spinning, and the transfer case has a mechanical speedo output for the gauge. The trans control computer only needs an ENGINE SPEED (RPM) signal and a throttle position signal. (And obviously the signals from the transmission itself.) Now if you wanted to use an electric speedometer then you would have to change some stuff to get the signal.
Man that thang is gonna be Killer.I'm in the midst of this swap now. Some of my photos will be reflective of me doing a dual transfer case at the same time as the 4L80E. I know, the ORD 203/205 “doubler” is expensive in itself so why not rub salt in the bleeding wallet wound and do the overdrive swap at the same time, right?
I am going to dump a bunch of photos in this thread as I make it through the swap. The cost of the doubler aside, I will say that I have $1,700 in my transmission ($200 for the core and another $1,500 for the rebuild). I chose to go with the US Shift “Quick 4” because I liked what I read in this thread about US Shift (Baumann Electronic Controls). The controller and harness was about $750. I chose to add the VSS to the output shaft of the NP205 and went with ORD’s $195 kit. Kevin from US Shift highly recommended that I go with the VSS on the output shaft of the tcase to allow maximum benefit from the features of the Quick 4. I chose to add a TPS to the injection pump. That was another $150. The Quick 4 needs a good TPS and VSS connection to work right.
The actual work began yesterday. The Muncie PTO, shaft, and crossmember with the carrier bearing will not be reinstalled.
Do all of the M1008’s have the TH400 “HD” or did they just put the Heavy Duty TH400 in my truck because it was an M1031 originally? I'm curious...
Not even close to yours Mike...Man that thang is gonna be Killer.
I'm looking forward to seeing how that 4L80e goes in and performs. Please post plenty of notes and photos to assist other SS members who are contimplating the same install.Not even close to yours Mike...
It seems that you are beginning to think like me. It's only money. Can't take it with you when you are gone. I've never seen a hearse pulling a U-Haul.
