The New Redneck workshop..
citizensoldier
19
Northern Michigan. Smelt City
Finished a liver transplant in the M109.. Old T case has a bearing going and howls like a chick at clinto's house. Could not hardly stand to listen or drive it anymore..
Swapped it out with a T case purchased from SS and mangus last year for a friend. They sold it to me I sold it to him and he sold it back to me..... That thing has some traveling miles on it.. :D :D
The replacement is so much nicer.. Thank you guys..
Now for the questions... Where can I buy some of the good reflectors both red and yellow? I dont want those cheap aftermarket ones. Ones with the good heavy rim..
I need a parking brake spring that holds it off the drum and hooks to the frame. Anybody have one.. Forgot to unhook it when letting the T case down and its about 4 times longer now. :lol: OOPs Only thing I trashed, so murphy must have been at Daves house today.
Last question.. How do you get those darn oil filters to seal!! Had them off twice and its leaking oil on my pretty engine!!! Any tricks to it?
builder77
OD Iron has the reflectors, and if they are like other things from him they should be the good stuff too. I plan to order a set with my next order too.
Opie
Salem, VA
The reflector circle comes loose from the "O" frame holding it to the truck, so any circular reflector of the proper size may be used.
citizensoldier
19
good point Opie.. Some of the housings are very rusty but I might be able to save them and just put new reflectors in them. I picked some up on ebay last year for my M37. They were junk and did not look right to me. I prefer the old style that is completely round but cant find any of those new.
1,164
Looks like the trusty old 109 is ready for the trip to the Ga. Rally.....
beetle
State College, Pennsylvania
oil filter seal
Before you put your new oil filters in ,reach up inside the top of your filter housing & make sure there are no o-rings or pieces stuck in there. Also do a good inspection with your finger tips or a mirror to make sure the o-ring seat is good. Clean everything super well & be careful to bolt the filter housing up as straight as possible. It's not always easy to get the new o-ring to seat.By the third oil change I had this part down pat.When I changed the filters the first time I found 2 old o-rings up inside my leaky rear filter.Good luck Beetle
m-35tom
226
eldersburg maryland
RE: oil filter seal
use new seal rings, do not use 'o' rings, i have seen all kinds of things in there for seals. clean everything and it will not leak
