THE ORIG. TRACTOR, WRECKER
No.2Diesel
11
Huntington, NY
More
Here are some Ops Manual shots...
No.2Diesel
11
Huntington, NY
Sterlings
Hi,
Here to finish this update are some pics of similar models Manufactured by Sterling. One is specified as a torpedo transporter, check out the bed!
captain-crank
Hamburg Mn
Hi Jeff,
How's it going?
Do you happen to know how the rear suspension was sprung on the 10 ton Sterling?
Judging from the one pic of the trucks rear, it looks very similar to a tandem set up that was put under a cadaver 8144 I have.
The pair in question I have are Timken top drives using one huge and thick leaf spring on each side.
Lower torque rods are attached to the axle housing same in as in picture.
Planning a de-mob since the whole thing is a bit bigger and slightly different design than the Wards rear drivers and won't work for spares.
Sad, but scrap is good and those dainty things weigh..........a lot.
John
Jeff Lakaszcyck
436
Mims, Florida
Capatain, I'm not sure if I can help you but I'll send you an email anyway. I have some some higer res pics of the above, and maybe some others. I want to say the rears were similar to your WLF and KW.
