Divemaster920
Banned
- 494
- 1
- 0
- VA
First I started draining the coolant; next I disconnected the batteries then removed the air filter housing. I could see the most rear freeze plug that needed to remove, then loosened the solenoid bracket for some room.
Then removed the freeze plug, I installed the Kat’s 600 watt heater. Part #11611. Zerostart part # is 3500025, and it is 1000w. The only reason I used Kat’s was because of the price.
Replaced coolant and air filter.
This install took less than an hour and I had to fish the freeze plug out of the block.
