I just put a new wiring harness in my M35A2 and new light switch. The flashers worked before I did this but now they dont work. I also installed a new thermal flasher unit with no luck and checked all grounds and bulbs and the wiring to a list of correct wire numbers. The only way I could get the turnsignals to flash was to connect the wires to a flasher unit out of my old dodge car. Which was a 12volt unit. Mine is 24 of course and it was getting all 24 volts at the flasher unit.
Does anyone happen to know why they wont work? Or maybe what I could check next?
Thanks,
Braindead
Thanks,
Braindead
