A different T-stat will not help.
To increase the operting temperature, cover the radiator. I could suggest use an electrically operated fan, but you need the air flow for proper temp distribution.
Keep in mind that the multifuel engine is a very efficient engine and will not put out a lot of heat unless working hard, just driving up and down the street will not get it hot, certainly not idling.
Over the years, I have found that a radiator cover is needed to some extent at all times. I finally made a custom plywood piece, which has the equivalent opening of canvas version with the flap open. The temperature still just nudges the T-stat to let it modulate the heat at about 180°F. That cover is left in place all year and if you live in a part of the country with real Winter weather, use the original radiator cover and close the flap until it's warmed up.
My 757 (8x
engine, also a multi, apparently was not operated much above 175°F, judging from the deposits left in the T-stat housing, the port that connects to the radiator is like new, while the "recirculation" port has the usual coolant deposits. It shows that during its life at Ft Sill, it was mostly at idle or not working very hard.
Get used to it, you are dealing with an engine made to work hard, so find other ways to get it hot.
BTW, the radiator will get warm via the lower portion, which contacts the coolant within the engine, it just won't contribute to the cooling.
To add a note here, I would like to see a radiator shutter for the deuce, because when you start driving it on the highways and hit a long down hill run, the temp will drop, and I have measured this, as much as 30 to 40 degrees F. A radiator shutter could prevent this temp drop, operated remotely or by its own temperature switch....
