Things that I have done and want to do
Jackel44
Fremont Nebraska
Things I have done:
Headlight relay bypass Take load off of headlight circuit and allowing greater amp draw on future lights
Electric fuel pump Makes it easier to prime filters
Filter housing replacement Makes it easier to change filters with a spin-on and fixes air leaking into fuel
In cab 12v fuse block
Doghead Starter relay Replace problematic relay
24v onboard charger To keep batteries up when it is in storage
Tilt Steering Helps a fat guy like me to drive
Things I want to do:
Headlight upgrade Allows for brighter bulbs **Do the headlight relay bypass first**
Glow plug resistor bypass Removes the problematic resistor
Glow plug relay Replaces old relay to prevent a break-down
Glow plug module swap Replace
33 12.5 r15 Adds about 4 mph on top speed and fills out fender wells
Turbo Increases horsepower and increases fuel mileage
Sound barrier in hood Decreases noise
Radio Does this need an explanation
Paint bed-liner on floor
Let me know if their are more important things I should be focusing on.
I will post pictures when the sun comes up
