Think I can fit these???
TenTires
225 RPM
52
Tidewater, VA
I think I found the next set of tires that I want to put on my deuce today. Not sure if I will have to lift it or not to make them fit......:wink:
TenTires
225 RPM
52
Tidewater, VA
:funny::funny::funny:
I like those better!! What the heck are those things?
Yep, the award goes to YankeeDeuce. That is the BARC @ Ft. Eustis. How'd you know that from that tiny pic??
11Echo
96
CT W. R.
Sources I've read say they are part of a Military program for supplying and protecting the Alaskan Tundra in the late 50's. Some others were tested in AZ in the early 60's. There is a "tractor" on display near Yuma, AZ. The is a tractor and some of the cargo trailers in a salvage yard behind Fort Wainright in Fairbanks. There are more remains of a tundra train near Alaska Pipeline Pumping Station #13. Built by the LeTourneau Company.
FM5332FF
Labelle, FL
i believe it was called a land train, correct me if i am wrong. one of the bigfoot trucks runs the tires, it was in orlando fl for the longest time before the place that owned it went out of business.
crazyplowboy
Champion, Ohio
They were known as snow trains. I saw it on the discovery channel a while back.
wreckerman893
Possum Connoisseur
15,647
2,141
That particular boondoggle was called the "Land Train".
Another idea that looked good on paper but was a nightmare in reality.
There was a junkyard in Yuma, AR, that had parts of one of them left that they bought out of Yuma Proving Grounds. I don't think they ever went into production and only a few prototypes were built.
They were powered by a diesel turbine that turned a generator, each wheel had an electric motor in it. They were to be used in the artic and desert environments where convoys of trucks could not go.
It had a "locomotive" where the crew operated it from and the engine/genny was located. It also had a kitchen, restrooms, crews quarters and freight cars.
Your tax dollars at work.:roll:
I visted that junkyard a few times and spoke to the owner about how he ahd acquired it. Seems he had a "connection" at the proving grounds and bought it for pennies on the dollar. It was so big he couldn't keep it whole. It was mostly aluminum so every tiime he needed quick cash he scrapped some more of it.
When I saw it there was only the control cabin, engine room and part of the crews quarters left.
There may be one whole example left but I can't remember.
YankeeDuece
Clifton Park, New York
"Yep, the award goes to YankeeDeuce. That is the BARC @ Ft. Eustis. How'd you know that from that tiny pic?? "
I saw the BARC in person, HUGE!! The give away was the bent-up Info marker low in the picture. Strangely, this I remember.
dc3coyote
19
Chattanooga TN
Wrecker the only remaning one is owned by a guy in Alaska, he has nearly a mile of the trailers that go behind the control cabin. It was posted a few months ago, on pirate 4x4.
The whole set up is for sale I think the owner is asking 20k.
If only I could get it in one shot, I think I may need a long load permit
wreckerman893
Possum Connoisseur
15,647
2,141
If only I could get it in one shot, I think I may need a long load permit [\QUOTE]
OK fellow steelsoldiers......time to take up collection.
Can you imagine bringing the control cab to a MV meet......it would be DA BOMB!!!!!
