Thoughts on this eBay front u-joint?
mikev
73
Culleoka, TN
Hello,
New guy here. :)
I have an 86 M1009 with 56K miles and I believe the original front (middle and rear) u-joints. I read up on the opinions of hollow. greasable ones verses solid ones. I plan to change them all out eventually...
What is your opinion of these for $10 each + shipping? I'm not trying to "cheap out" as I only want to do these u-joints once (if that is possible...)
Thanks in advance everyone!
EDIT: Didn't realize I should not post links to eBay auctions - sorry...
So, if those front u-joints are actually USGI, NSN issue, would they be durable enough for your (my) CUCV or should I go after-market like Brute Force, etc?
D
Deleted member 11142
Guest
your not suposed to post links to active auctions....
CARNAC
The Envelope Please.
725
College Station, TX
However you could download the TM, pull out that page and post it with the same question. Just can't direct link to an active auction. It can lead to an illegal act called collusion.
Suggest editing your post and redoing the attachment as stated above.
wreckerman893
Possum Connoisseur
15,647
2,141
These are standard GM parts....should be able to get them at the usual suspects (Advance, O' Reily's, NAPA, etc.).
If they are not the right parts you can just take them back....not have to worry about getting a refund from an on line seller.
Just my two cents worth.
