Thread type and size of oil line radiator left - M1009 / Chevrolet Blazer K5 Diesel
87cr250r
2,104
Rodeo, Ca
It's in a difficult spot to see. It's on the passenger side, behind your alternator next to the timing cover, just below where the head meets the block. I actually permanently tapped mine with a stainless steel tube so I can get oil pressure from it.
Elektroman99
138
Siegburg, Germany
Can I use a T piece with pressure and temperature decrease? What connections do I need there? Is that a line that goes from there? I am aware that the oil temperature is actually close to the water temperature. It's about being warned if both temperatures rise too quickly or deviate greatly.
87cr250r
2,104
Rodeo, Ca
You can't measure temperature at a dead end, it has to be somewhere with flow. It's easy to get the pan off the truck. Put the temp sensor there.
I will repeat, however, oil temperature is unimportant on these engines. If you want to know the oil temp, just add 10°F to the coolant temp.
Jbulach
2,396
Sunman Indiana
I’m guessing he want to read transmission fluid/oil temperature and pressure via the cooler lines? I don’t think this is a good place to measure either, especially pressure…
Elektroman99
138
Siegburg, Germany
Pressure should be the same everywhere in a closed system, especially with liquids, because they cannot be compressed more at one point than at another.
Temperature should be only minimally different in both lines to the cooler. However, we now know that the sensor pickup point on the front left of the engine block is a "dead end" and will deviate at the temperature.
In the oil pan I did not want to work anything in, because I can neither cut a thread, nor necessarily at a deep point of the vehicle to attach a shock-sensitive sensor.
Somehow the whole realization of the Diskusssion is difficult for me to interpret. Apparently, the aluminum block with analysis decrease points in the two lines that go to the radiator has been a not so bad idea, in the thead of the other forum.
