motormayhem
- 13
- 18
- Tucson, AZ
Even with a NOS throttle cable I am seeing the pedal does not travel far enough to activate the kick down switch. It will move enough to set the switch, but then it will just barely touch it at WOT.
I've checked the following and nothing seems to be adjustable so I am confused as to what is causing this? I also noticed the pedal has another inch or so to go when the throttle cable gets tight before it would be bottomed on the floor. Is that typical? Seems like if you mash the pedal and are hard stopping the link on the IP that puts a lot of stress on the IP and cable? Can anyone confirm what their pedal travel looks like in relation to the kick down and floor of the cab?
Checked:
Checked:
- NOS throttle cable (so length, etc should be right)
- Bracket on injection pump is non-adjustable
- Pedal bracket/kickdown switch non-adjustable
