- 2,052
- 56
- 48
- Milford / Michigan
Does anybody know the correct size o-ring for the throttle stop shaft on the injection pump? I was told it was a "-013" but that is not the correct one. On my other deuce, I bought the injection pump gasket kit and used the o-ring supplied and it worked like a charm. this "-013" is too thick in diameter. The diameter of the "-013" is 1/16" and it needs to be smaller. I have searched high and low and I cant seem to find the right o-ring other than buying the entire kit. It's got me bummed out tonight because I cant fix it the correct way. When the o-ring is too big like the one in it now, it makes the throttle sticky (not in a dangerous way... just makes the engine surge), so its a pain to drive. Thanks for everybodys help.
