thunk thunk knock knock in left rear????
teteacher101
WI
Would one of you who have purchased these shafts please put up a simple posting with the 3 part numbers for these shafts for the rest of us?
My HMMWV: 1989 M998A0
Vendor: Autozone
Rear: 16060N (this is the only one I got)
Fronts: 16058N and 16059N
I am sorry I am not sure which side is which as it shows 3 shafts in their system/website but not location and the counter person couldn't tell either. I was told if it's wrong just bring it back an they would return it. So if it was me I'd buy both an return the other one or just replace them both since they are only $100 each an just be done with it.
papakb
1,196
San Jose, Ca
Both rear shafts are the same length, right front is the longest, left front is the shortest. Autozone's website shows their weights as:
16058 = 20.58# Left front
16059 = 22.05# Rear shafts
16060 = 22.93# Right Front
These are for the 10K shafts, the 12K shafts are another story.
teteacher101
WI
When I run those part numbers on Autozones website I don't see where it shows it being Rear, RF, or LF. Did I miss that somewhere or is that from your experience with these? Also the shaft that fit mine for the rear is 16060N. Was that just a typo or a glitch on their site or?
McSpeed
293
Palmer, AK
My new one 100% fixed the problem. Quiet and smooth as can be.
I only wish it came pre-painted so it could have been installed immediately.
papakb
1,196
San Jose, Ca
teteacher101, I was going by the weights listed for the shafts on the Autozone site. 22.9# would be the heaviest so it should be the longest shaft, the right front. The left front is the shortest so it makes sense that the lightest shaft at 20.5# would go there and the middleweight shaft at 22.05 would fit the rears where both are the same length. You might be able to compress the right front to fit in the rear but it won't have the same amount of travel as the wheel moves up and down so I'd be careful there.
teteacher101
WI
In theory that would make sense and a person would think that unless there is a mistake somewhere on their part with the weights listed/part number/etc.-not sure I guess? The right front shaft is a lot longer-about 2.5" longer when compared to the rear shaft so I don't think a person could even get it in there if you tried and if you did I don't think there would be enough play to compress it when trying to reattach the upper ball joint to the knuckle. The rear shaft was very close to going in without popping the ball joint up, it may in fact have made it with a little "buffing" on the rotor, and some harder prying actually.
Maybe if someone has a couple of bad shafts or a bunch of bad boots they could be the guinea pig an order all new shafts from Autozone an report back!
