lovebloodhounds
- 3
- 18
- coshocton Ohio
I know it has been cover many times but please help any suggestions on the easy way to put the front axle booots on a deuce .please help they are wipping me . thank you all Kenneth
same hereRecovry4x4 said:I run both clamps at 12.00
The clamp goes at 12 as Recovery 4x4 stated. The clamp can only go at top as it sits above the zipper on the boot. I thought about putting it on bottom NG rubber pulls in and will leak. The top is where it needs to be.ucfjeeper said:What about clamp bolt location? I think I"ve seen somewhere that the proper orientation on the inner boot clamp is at 11 or 2 o'clock position or something and then the outter boot clamp is at the 12 o'clock position. Something to do with helping keep the boot from tearing when steering. I would like to know what the correct positions are as I am about to swap out my boots.
oh,.... and yeungling is great. Used to drink it all the time when I lived up in Jersey. Now, it's a little more expensive to drink it down here in FL and not every place carries it.
There might be a difference between the 2 1/2 deuce and the 5 Ton which I am working on but the way it assembles the same. The manual for 5 Ton states zipper to the top. Check the TM Manual which you can download from resources folder.ucfjeeper said:the zipper goes on top? I thought the zipper went on the bottom? My boots have "top" molded into them.
