Tips on pulling tranny?
MVrookie
Reno,NV
Any tips or cautions on dropping the tranny? The second syncro ring back seem imbedded into the gear. my tranny guy says pull the tranny and he'll make it right. The existing threads do not seem to suggest any great problem removing the transmission.
Thanks all!
Trango
23
Boulder, CO
I've been told it's easy to roll the windows down, lay a piece of lumber (I'd nail 2 2x4's together into a 4x4) across the tops of the windowsill, and then use a ratchetstrap or a small hand winch off that.
On install, use long 3/8" bolts as temporary pilot studs to guide the tranny into place.
tx399999
Tulsa, Oklahoma
Make sure it's in first gear. It pulls in the rod for the sprag gear. If it's in neutral or even worse reverse, it will be a pain to get out and never go back in.
When I pulled mine I ran two 2x4s through the windshield and the back window of the hard top. With a chain hoist and a furniture dolly underneath it is almost a one man job.
Warthog
231
OKC, OK
Use the above tip of a 4x4 or 2-2x4s thru the open windshield and a chain hoist. And putting it in 1st gear.
I can have one out is 30-45 minutes. The longest time is removing the bolts holding down the sheetmetal :-D
Trango
23
Boulder, CO
Warthog
231
OKC, OK
Yes that is very possible but you might need the doors open when you work on the truck.
One thing that makes this job easier is to remove the passenger seat. It allows much more room to work.
saddamsnightmare
80
Abilene, Texas
January 11th, 2010.
Will Wagner has experience with this one, he puts the girder from side door window sill to side door window sill and brings it up, through the cab, so I'm told. Apparently in any case its a lot easier then some newer trucks and cars.... just big and bulky.
Cheers,
Kyle F. McGrogan:-D
mckeeranger
Eastern Kentucky
I haven't done it yet, but I was going to take out the passenger seat, the floor sheet metal, and then roll a hydraulic engine hoist through the passenger side door. Then set it down onto a dolly.
MVrookie
Reno,NV
The reason I'm pulling the tranny out, is the thing is stuck in neutral with a jamed syncro.
I cannot put the tranny in 1st gear. will it make a difference?
1,807
The hoist works. The 4x4 from the back of the cab out the windshield works. When you sling your hoist on the wood, put it through a piece of pipe so you can roll it back and forth. If it's stuck in N, pull the cover off.
G-Force
allendale nj
Thanks all!
The most important thing you need to remember is
"DON'T DROP IT"!!!!!!!
IMA944T
OKLAHOMA CITY
So why is it hard to pull trans with it in gear?? Does it not have a input shaft that comes out of clutch like a normal car trans? Slip out and slip back in?
Warthog
231
OKC, OK
There are just so many bolts in the covers is the problem. Time consuming.......
The sprag shaft (not hooked up on the airshift trucks) hits the cross member and makes the input shaft alignment harder if the tranny isn't in 1st gear. Do able in neutral but easier in 1st.
